* | libtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 1 | -1/+1 |
| | | | | Update #3818. | ||||
* | tests: Remove CONFIGURE_MAXIMUM_DRIVERS | Sebastian Huber | 2018-08-07 | 1 | -3/+0 |
| | | | | This configuration is superfluous in these tests. | ||||
* | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | termios: Remove obsolete configuration options | Sebastian Huber | 2018-02-05 | 1 | -3/+0 |
| | | | | Update #2843. | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 1 | -1/+20 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -1/+9 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-07-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-19 | 5 | -0/+226 |
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for XON/XOFF and VMIN/VMAX cases. * termios07/.cvsignore, termios07/Makefile.am, termios07/init.c, termios07/termios07.doc, termios07/termios07.scn, termios08/.cvsignore, termios08/Makefile.am, termios08/init.c, termios08/termios08.doc, termios08/termios08.scn: New files. |
