path: root/testsuites/libtests/termios06 (follow)
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* libtests: Avoid build system defined definesSebastian Huber2019-11-121-1/+1
| | | | Update #3818.
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* termios: Remove obsolete configuration optionsSebastian Huber2018-02-051-3/+0
| | | | Update #2843.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* tests: Use rtems_test_printer in generalSebastian Huber2017-10-281-0/+1
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* termios: Synchronize with latest FreeBSD headersKevin Kirspel2017-03-222-14/+8
| | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-213-3/+3
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-2/+6
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-112-2/+18
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-114-11/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-2/+1
| | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-222-0/+8
* 2011-01-28 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2011-01-283-0/+40
| | | | | | | | PR 1661/testing * termios06/init.c: Extend the test to cover sections related to flow control in termios.c * termios06/termios06.doc: Updated test concept * termios06/termios06.scn: Updated test run log
* 2010-07-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-191-0/+35
| | | | | | | | | * Makefile.am, configure.ac, termios06/init.c: Add initial tests for XON/XOFF and VMIN/VMAX cases. * termios07/.cvsignore, termios07/Makefile.am, termios07/init.c, termios07/termios07.doc, termios07/termios07.scn, termios08/.cvsignore, termios08/Makefile.am, termios08/init.c, termios08/termios08.doc, termios08/termios08.scn: New files.
* 2010-07-06 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-062-1/+9
| | | | | * termios06/init.c, termios06/termios06.scn: Add a couple more PPPDISC cases. Coverage of these paths is near complete.
* 2010-07-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-056-0/+338
* Makefile.am, configure.ac, malloc03/init.c: Add test for PPPDDISC. * termios06/.cvsignore, termios06/Makefile.am, termios06/init.c, termios06/termios06.doc, termios06/termios06.scn, termios06/test_pppd.c: New files.
