Update #3382
Update #2843.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
PR 1661/testing
* termios06/init.c: Extend the test to cover sections related to
flow control in termios.c
* termios06/termios06.doc: Updated test concept
* termios06/termios06.scn: Updated test run log
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
* termios06/init.c, termios06/termios06.scn: Add a couple more PPPDISC
cases. Coverage of these paths is near complete.
* Makefile.am, configure.ac, malloc03/init.c: Add test for PPPDDISC.
* termios06/.cvsignore, termios06/Makefile.am, termios06/init.c,
termios06/termios06.doc, termios06/termios06.scn,
termios06/test_pppd.c: New files.
