Updates #3053.
Update #3753.
This configuration is superfluous in these tests.
Update #2843.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* Makefile.am, configure.ac: Add new test to exercise termios RX and TX
interrupt driven IO support.
* termios04/.cvsignore, termios04/Makefile.am, termios04/init.c,
termios04/termios04.doc, termios04/termios04.scn,
termios04/termios_testdriver_intr.c,
termios04/termios_testdriver_intr.h: New files.
* termios03/init.c, termios03/termios03.doc, termios03/termios03.scn,
termios03/termios_testdriver_polled.c,
termios03/termios_testdriver_polled.h: Add more test cases.
* termios03/.cvsignore, termios03/Makefile.am, termios03/init.c,
termios03/termios_testdriver_polled.h: New files.
* Makefile.am, configure.ac: Add initial version of new test for polled
IO support in termios.
