This configuration is superfluous in these tests.
Update #2843.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Remove obsolete support for OFILL, OFDEL, NLDLY, CRDLY, BSDLY, VTDLY,
and FFDLY which is not present on FreeBSD and not implemented in Linux.
Update #2833.
* Makefile.am, configure.ac, malloctest/init.c, termios03/init.c,
termios03/termios03.scn: Handle some of the VKILL and VERASE cases.
* termios03/init.c, termios03/termios03.doc, termios03/termios03.scn,
termios03/termios_testdriver_polled.c,
termios03/termios_testdriver_polled.h: Add more test cases.
* termios03/.cvsignore, termios03/Makefile.am, termios03/init.c,
termios03/termios_testdriver_polled.h: New files.
* Makefile.am, configure.ac: Add initial version of new test for polled
IO support in termios.
