* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* termios01/init.c, termios01/termios01.scn, termios02/init.c,
termios02/termios02.scn: Add tests for cfigetspeed(), cfogetspeed(),
cfisetspeed(), cfosetspeed(), ctermid(), tcflow(), tcflush(),
tcsendbreak(), tcsetpgrp(), and tcgetpgrp(). Some of these methods
are minimal implementations so the tests will have to grow as the
methods grow.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
