CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
New IO control RTEMS_IO_TCFLUSH.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* termios01/init.c, termios01/termios01.scn, termios02/init.c,
termios02/termios02.scn: Add tests for cfigetspeed(), cfogetspeed(),
cfisetspeed(), cfosetspeed(), ctermid(), tcflow(), tcflush(),
tcsendbreak(), tcsetpgrp(), and tcgetpgrp(). Some of these methods
are minimal implementations so the tests will have to grow as the
methods grow.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
