* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -7/+7 |
* | 2009-08-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-15 | 1 | -0/+157 |
* Makefile.am, configure.ac: Add new test to exercise tcgetattr and tcsetattr. Does a variety of baud, parity, stop bits, and bits per character with the assistance of a special test driver which prints the requests. * termios01/.cvsignore, termios01/Makefile.am, termios01/init.c, termios01/termios01.doc, termios01/termios01.scn, termios01/termios_testdriver.c, termios01/termios_testdriver.h: New files. |
