* | termios: Add rtems_termios_set_best_baud() | Sebastian Huber | 2014-07-09 | 1 | -0/+4 |
* | termios: PR2153: New low-level device API | Sebastian Huber | 2014-07-09 | 1 | -0/+5 |
| | | | | | | | | | | | | | | | | | Add a new low-level device API to Termios that passes the TTY structure to the low-level device functions. This greatly simplifies the low-level device drivers since they are no longer forced to derive their private data from the minor number. It makes it possible to use the TTY low-level lock in the device driver low-level functions which is necessary for proper SMP support. For example to set the attributes it is often necessary to perform a read-modify-write operation on a control register used also by interrupt routines. A compatibility layer is provided to support device drivers using the old callback functions so it is not necessary to modify existing device drivers. | ||||
* | libtests/termios01: Add tests for cfsetspeed() and cfmakeraw() | Daniel Ramirez | 2014-01-09 | 1 | -0/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-08-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-15 | 1 | -0/+30 |
* Makefile.am, configure.ac: Add new test to exercise tcgetattr and tcsetattr. Does a variety of baud, parity, stop bits, and bits per character with the assistance of a special test driver which prints the requests. * termios01/.cvsignore, termios01/Makefile.am, termios01/init.c, termios01/termios01.doc, termios01/termios01.scn, termios01/termios_testdriver.c, termios01/termios_testdriver.h: New files. |
