Do not generate the test tar archive on the host computer since not all
file systems support symbolic links.
Close #3968.
Update #3753.
Use uniform pattern for all TAR file names. Use the dl* tests as a
template.
Update #3818.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
