This simplifies the build process. Do not generate the archive content
through the build system. Let the version control system deal with
symbolic links.
Update #3818.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
See also:
https://www.gnu.org/software/automake/manual/html_node/Built-Sources-Example.html
Add support to untar XZ compressed files.
This patch parses the mode field in the tar header and sets the
directory or file to the mode value in the header.
Closes #2768.
Support creating directories for files with a path depth greater than 1. Some
tar files can have files with a path depth greater than 1 and no directory
entry in the tar file to create a directory.
Support overwriting existing files and directories failing in a similar
way to tar on common hosts. If a file is replaced with a file delete the
file and create a new file. If a directory replaces a file remove the file
and create the directory. If a file replaces a directory remove the directory,
and if the directory is not empty and cannot be removed report an error. If a
directory alreday exists do nothing leaving the contents untouched.
The untar code now shares the common header parsing and initial processing
with the actual writes still separate. No changes to the IMFS have been made.
Updates #2415.
Closes #2207.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* devfs04/Makefile.am, deviceio01/Makefile.am,
monitor02/Makefile.am, stackchk01/Makefile.am,
tar02/Makefile.am, termios01/Makefile.am,
tztest/Makefile.am: Add missing files.
* tar01/init.c: Fixed integer types.
* tar01/Makefile.am, tar02/Makefile.am: Apply clean-local to remove
intital_fs directory.
* tar01/Makefile.am, tar02/Makefile.am: Apply TARTESTS.
* tar01/Makefile.am:
Apply $LN_S, $PAX. Use subshell for tarball creation.
Don't add initial_fs to CLEANFILES.
* tar02/Makefile.am:
Eliminate stamp-filesystem.
Add BUILT_SOURCES.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
* tar01/Makefile.am, tar02/Makefile.am: Fix dependencies for parallel
build.
* tar01/Makefile.am, tar02/Makefile.am: Replace mkdir cascade
with $(MKDIR_P).
* tar01/Makefile.am, tar02/Makefile.am: Misc. fixes.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
