Updates #3053.
RTEMS untar implementation had problems with overwriting or integrating
archives into existing directory structures. This patch adapts the
behavior to mimic that of a GNU tar or BSD tar and extends the tar01
test to check for the behavior. That is:
* If a directory structure exists, the files from the archive will be
integrated. Existing files are overwritten.
* If a file exists and the archive contains a directory with the same
name, the file is removed and a directory is created. In the above
example: if l1/l2 is a file it will be overwritten with a new
directory.
* If a directory exists and the archive contains a file with the same
name, the directory will be replaced if it is empty. If it contains
files, the result is an error.
* An archive also can contain only a file without the parent
directories. If in that case one of the parent directories exists as a
file extracting the archive results in an error. In the example: if
l1/l2 is a file and the archive doesn't contain the directories but
only the file l1/l2/x.txt that would be an error.
* In case of an error, it is possible that the archive has been
partially extracted.
Closes #4568
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
