* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libnetworking: Typo | Sebastian Huber | 2014-03-06 | 1 | -1/+21 |
* | libtests: Add contents to rbheap and stackchk documentation files | Cynthia Rempel | 2014-01-09 | 1 | -5/+18 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -0/+3 |
* | networking: socket to/from file descriptor | Sebastian Huber | 2012-04-03 | 4 | -0/+147 |
o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to "cpukit/libnetworking/rtems/rtems_syscall.c". o The rtems_bsdnet_makeFdForSocket() function is now static. o Check in rtems_bsdnet_fdToSocket() function that the file descriptor uses the socket handlers, otherwise an error status will be returned and errno set to ENOTSOCK. o New test libtests/syscall01. |
