#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
This makes the test more reliable in case an interrupt driven console
driver is used.
Send a special event to notify tasks waiting for a socket state change
in case this socket gets closed. This prevents a use after free.
Close #785.
o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to
"cpukit/libnetworking/rtems/rtems_syscall.c".
o The rtems_bsdnet_makeFdForSocket() function is now static.
o Check in rtems_bsdnet_fdToSocket() function that the file descriptor
uses the socket handlers, otherwise an error status will be returned
and errno set to ENOTSOCK.
o New test libtests/syscall01.
