* | libtests: Add contents to rbheap and stackchk documentation files | Cynthia Rempel | 2014-01-09 | 1 | -5/+18 |
* | networking: socket to/from file descriptor | Sebastian Huber | 2012-04-03 | 1 | -0/+11 |
o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to "cpukit/libnetworking/rtems/rtems_syscall.c". o The rtems_bsdnet_makeFdForSocket() function is now static. o Check in rtems_bsdnet_fdToSocket() function that the file descriptor uses the socket handlers, otherwise an error status will be returned and errno set to ENOTSOCK. o New test libtests/syscall01. |
