* devfs04/Makefile.am, deviceio01/Makefile.am,
monitor02/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am,
tar02/Makefile.am, termios01/Makefile.am,
termios03/Makefile.am, termios04/Makefile.am
tztest/Makefile.am: Add missing files.
* stringto01/init.c: Redefine LONG_LONG_MAX and LONG_LONG_MIN
for c99.
* stringto01/init.c, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: Attempt to pick up a few more
error paths.
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* stringto01/init.c: New file.
* Makefile.am, configure.ac: Add string_to_xxx conversion test.
* stringto01/.cvsignore, stringto01/Makefile.am,
stringto01/stringto01.doc, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: New files.
