path: root/testsuites/libtests/stringto01/stringto_test_template.h (follow)
* libtests/stringto01: Fix for GCC 5.0Sebastian Huber2015-03-091-13/+18
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-1/+4
* 2011-07-29 Pawel Zagorski <pzagor@agh.edu.pl>Joel Sherrill2011-07-291-0/+18
| | | | | | | PR 1865/tests * stringto01/Makefile.am, stringto01/init.c, stringto01/stringto01.doc, stringto01/stringto01.scn, stringto01/stringto_test_template.h: Improve coverage of string conversion routines.
* 2010-07-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-191-0/+20
| | | | | | * stringto01/init.c, stringto01/stringto01.scn, stringto01/stringto_test_template.h: Attempt to pick up a few more error paths.
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-15/+15
| | | | | | | | | | * block01/init.c, block02/init.c, block03/init.c, block04/init.c, block05/init.c, block07/init.c, bspcmdline01/init.c, stringto01/init.c, stringto01/stringto_test_template.h, termios01/init.c, termios01/termios_testdriver.c, termios02/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* 2009-12-01 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-12-011-0/+152
* Makefile.am, configure.ac: Add string_to_xxx conversion test. * stringto01/.cvsignore, stringto01/Makefile.am, stringto01/stringto01.doc, stringto01/stringto01.scn, stringto01/stringto_test_template.h: New files.
