PR 1865/tests
* stringto01/Makefile.am, stringto01/init.c, stringto01/stringto01.doc,
stringto01/stringto01.scn, stringto01/stringto_test_template.h:
Improve coverage of string conversion routines.
* Makefile.am, configure.ac: Add string_to_xxx conversion test.
* stringto01/.cvsignore, stringto01/Makefile.am,
stringto01/stringto01.doc, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: New files.
