Update #3082.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
PR 1865/tests
* stringto01/Makefile.am, stringto01/init.c, stringto01/stringto01.doc,
stringto01/stringto01.scn, stringto01/stringto_test_template.h:
Improve coverage of string conversion routines.
* stringto01/init.c: Redefine LONG_LONG_MAX and LONG_LONG_MIN
for c99.
* stringto01/init.c, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: Attempt to pick up a few more
error paths.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* stringto01/init.c: New file.
