Move Heap_Information_block to separate header file to hide heap
implementation details from <rtems.h>.
Update #3598.
Update #3533.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #2825.
of this patch set.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* stackchk/init.c, stackchk/system.h, stackchk/stackchk.scn: Print end
of test message.
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* stackchk/blow.c, stackchk/stackchk.scn: Print a stack check report
before blowing stack.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
* malloctest/init.c: New test cases. Update for heap API changes.
* stackchk/blow.c: Update for heap API changes.
* heapwalk/init.c, stackchk/blow.c: Update for heap API changes.
* malloctest/task1.c, stackchk/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* cpuuse/task1.c, cpuuse/tswitch.c, malloctest/task1.c,
stackchk/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* stackchk/stackchk.scn: Correct screen to match output.
* stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* cpuuse/init.c, malloctest/init.c, monitor/init.c, monitor02/init.c,
putenvtest/init.c, rtems++/Init.cc, rtmonuse/init.c, stackchk/init.c:
Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all
POSIX tests. Add a clock_settime case for < 1988.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
