2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-09-08 | libtests/sha: Add tests for SHA512-256 | Sebastian Huber | 1 | -0/+49 | |
2022-09-08 | libtests/sha: Add tests for SHA512-224 | Sebastian Huber | 1 | -0/+50 | |
2022-09-08 | libtests/sha: Add tests for SHA384 | Sebastian Huber | 1 | -0/+58 | |
2022-09-08 | libtests/sha: Add tests for SHA224 | Sebastian Huber | 1 | -4/+54 | |
2022-04-07 | testsuites/libtests/[p-z]*: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2020-09-30 | libtests/sha: Fix test if -O0 is used | Sebastian Huber | 1 | -0/+11 | |
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | 1 | -2/+0 | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | 1 | -0/+2 | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||||
2014-12-16 | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 1 | -2/+0 | |
This define was superfluous, undocumented and used inconsistently. | |||||
2014-11-20 | Add SHA256 and SHA512 support | Sebastian Huber | 1 | -0/+191 | |
