* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* rtmonuse/init.c: Do not use Task_name array before initialized.
* cpuuse/init.c, malloctest/init.c, monitor/init.c, monitor02/init.c,
putenvtest/init.c, rtems++/Init.cc, rtmonuse/init.c, stackchk/init.c:
Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all
POSIX tests. Add a clock_settime case for < 1988.
* rtmonuse/init.c, rtmonuse/task1.c: Add period which is unused to
exericise another path in the period statistics code.
* cpuuse/task2.c, rtmonuse/rtmonuse.scn, rtmonuse/task1.c: Add new
cases for untested routines.
* ChangeLog, rtmonuse/task1.c: Clean up output and use FLUSH_OUTPUT()
macro instead of fflush() directly.
* rtmonuse/init.c, rtmonuse/task1.c: Integrate Rate Monotonic
Statistics and Period Usage into Rate Monotonic Manager. Added the
following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c,
monitor/system.h, rtems++/System.h, rtems++/Task1.cc,
rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c,
rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to
using c99 fixed size types.
* cpuuse/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* malloctest/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* putenvtest/Makefile.am: Ditto.
* rtems++/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* termios/Makefile.am: Ditto.
PR 544/tests
* malloctest/system.h, rtmonuse/system.h: Various modifications to make
tests account for resources and not print at inappropriate times.
* cpuuse/Makefile.am: Remove all-local: $(ARCH).
* malloctest/Makefile.am: Remove all-local: $(ARCH).
* monitor/Makefile.am: Remove all-local: $(ARCH).
* putenvtest/Makefile.am: Remove all-local: $(ARCH).
* rtems++/Makefile.am: Remove all-local: $(ARCH).
* rtmonuse/Makefile.am: Remove all-local: $(ARCH).
* stackchk/Makefile.am: Remove all-local: $(ARCH).
* termios/Makefile.am: Remove all-local: $(ARCH).
* cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c,
cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c,
malloctest/system.h, malloctest/task1.c, monitor/init.c,
monitor/system.h, putenvtest/init.c, rtems++/Init.cc,
rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c,
stackchk/blow.c, stackchk/init.c, stackchk/system.h,
stackchk/task1.c: URL for license changed.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
more accurate.
enclose.
tasks table.
