1997-04-09 | new test | Joel Sherrill | 1 | -0/+0 | |
1995-09-27 | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1 | -15/+15 | |
stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
1995-08-23 | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1 | -15/+15 | |
Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | |||||
1995-08-18 | Changed to reflect adding object class to id | Joel Sherrill | 1 | -15/+15 | |
1995-05-24 | Fully tested on all in-house targets | Joel Sherrill | 1 | -1/+1 | |
