Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib().
Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and
CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options.
Update #3904.
It was accidentally committed.
This reverts commit a314544a278f1533ae001f742d7fe24fcee253e6.
Introduce new library librtemsrecordwrap.a which contains wrappers for
operating system functions which produce entry/exit events.
The wrappers can be selected during link time via the GNU ld --wrap
option.
Update #3665.
Add system events for memory allocation/free.
Update #3665.
Add system events to identify the target system. Add system events to
transfer blocks of memory and register sets.
Update #3665.
Reduce the system dependencies to allow tracing of very low level
functions, for example the interrupt disable/enable.
Introduce general purpose RTEMS_RECORD_CALLER and RTEMS_RECORD_LINE
events.
Update #3665.
This is a minor optimization.
In case of a ring buffer overflow, the rtems_record_drain() will push
the complete ring buffer content to the client. While the items are
processed by the client, new items may overwrite some items being
processed. The overwritten items can be detected in the following
iteration once the next tail/head information is pushed to the client.
Update #3665.
Add low level event recording infrastructure for system and user
defined events. The infrastructure is able to record high frequency
events such as
* SMP lock acquire/release,
* interrupt entry/exit,
* thread switches,
* UMA zone allocate/free, and
* Ethernet packet input/output, etc.
It allows post-mortem analysis in fatal error handlers, e.g. the last
events are in the record buffer, the newest event overwrites the oldest
event. It is possible to detect record buffer overflows for consumers
that expect a continuous stream of events, e.g. to display the system
state in real-time.
The implementation supports high-end SMP machines (more than 1GHz
processor frequency, more than four processors).
Add a new API instead. The implementation uses per-processor data
structures and no atomic read-modify-write operations. It is uses
per-processor ring buffers to record the events.
The CPU counter is used to get the time of events. It is combined with
periodic uptime events to synchronize it with CLOCK_REALTIME.
The existing capture engine tries to solve this problem also, but its
performance is not good enough for high-end production systems. The
main issues are the variable-size buffers and the use of SMP locks for
synchronization. To fix this, the API would change significantly.
Update #3665.
