* | rbheap01/init.c: Fix PAGE_SIZE redefined warning | Joel Sherrill | 2017-06-21 | 1 | -37/+37 |
* | rbheap: Fix rtems_rbheap_free() | Sebastian Huber | 2015-09-11 | 1 | -0/+5 |
| | | | | | | | Remove unused descriptor of merged free chunks from the free chain and add them to the spare descriptors. Close #2417. | ||||
* | libtests/rbheap01: Simplify | Sebastian Huber | 2015-09-11 | 1 | -172/+95 |
| | | | | Update #2417. | ||||
* | rbheap: Drop direction from _RBTree_Iterate() | Sebastian Huber | 2015-08-31 | 1 | -2/+0 |
* | rbtree: Add and use RBTree_Compare_result | Sebastian Huber | 2014-08-05 | 1 | -17/+0 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libtests: Add contents to rbheap and stackchk documentation files | Cynthia Rempel | 2014-01-09 | 1 | -0/+145 |
* | score/rbtree: Remove "unprotected" from API | Sebastian Huber | 2013-11-21 | 1 | -1/+1 |
* | score: Create rbtree implementation header | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | | | Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | ||||
* | libtests/rbheap01: Add test cases | Sebastian Huber | 2012-12-22 | 1 | -0/+42 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -0/+3 |
* | rbheap: API changes and documentation | Sebastian Huber | 2012-04-18 | 1 | -38/+51 |
* | rbheap: New files | Sebastian Huber | 2012-04-11 | 4 | -0/+603 |
In the Red-Black Tree Heap the administration data structures are not contained in the managed memory area. This can be used for example in a task stack allocator which protects the task stacks from access by other tasks. |
