Update #3753.
Update #3818.
Update #3382
Update #2843.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
of this patch set.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* mouse01/init.c: Account for extra message buffer size.
* mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c:
Add HAVE_CONFIG_H.
* mouse01/serial_mouse_config.c: Avoid output due to execution context.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
