* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+43 |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 2 | -4/+2 |
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 1 | -0/+1 |
| | | | | more accurate. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 2 | -2/+2 |
* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 1 | -1/+1 |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 2 | -4/+4 |
* | Added Monitor test. | Joel Sherrill | 1997-09-21 | 2 | -0/+131 |
