* | libtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 1 | -0/+3 |
| | | | | Update #3818. | ||||
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-31 | 1 | -269/+7 |
| | | | | This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f. | ||||
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-31 | 1 | -7/+269 |
| | | | | This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b. | ||||
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-24 | 1 | -269/+7 |
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-23 | 1 | -7/+269 |
* | libtests/math*: Avoid generated files | Sebastian Huber | 2012-05-22 | 1 | -269/+7 |
| | | | | Use C pre-processor instead of shell commands. | ||||
* | 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-13 | 1 | -1/+3 |
| | | | | | | * math/init.c, mathf/init.c, mathl/init.c: Move configuration section. * math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate. * math/domath.in: Generate domath* prototype. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | New (Split out from math/). | Ralf Corsepius | 2011-02-02 | 1 | -0/+281 |
