Update #3170.
Update #3199.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
of this patch set.
* math/init.c, mathf/init.c, mathl/init.c: Move configuration section.
* math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate.
* math/domath.in: Generate domath* prototype.
* math/init.c, mathf/init.c, mathl/init.c: Now run.
