Update #3382
Update #3170.
Update #3199.
This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f.
This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b.
Use C pre-processor instead of shell commands.
for details.
* math/Makefile.am, math/init.c: Init task has to be floating point and
there is no point in using optional manager stubs since libio needs
semaphores.
