* | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-01 | 1 | -1/+1 |
| | | | | | | * malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+1 |
| | | | | | | * cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Include compile.am | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 3 | -8/+478 |
* | New file. | Joel Sherrill | 2000-05-24 | 1 | -0/+0 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+42 |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 3 | -6/+3 |
* | Patch from John S Gwynne <jsg@donet.com> for malloctest. His comments: | Joel Sherrill | 1999-02-03 | 2 | -6/+12 |
| | | | | | | | | | | I have a few patches for the efi332 bsp. If you let me know when you expect the next snapshot release, I will try to have them to you before then. Also, the malloctest has some problems that I would think would prevent it from running on almost any platform. I have enclose patches below to fix (1) Task_id and Task_name dimensioning, (2) end of test message, (3) the amount of memory malloc'ed, and (4) retry on unsuccessful (out of memory) molloc's. | ||||
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 1 | -2/+4 |
| | | | | more accurate. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 3 | -0/+230 |
(ostertag@transition.com) |
