* malloctest/init.c: Update for heap API changes.
PR 1617/testing
* malloctest/init.c: Added new case to exercise _realloc_r.
* malloctest/init.c: Added test for
rtems_heap_allocate_aligned_with_boundary().
* malloctest/system.h: Enable malloc statistics.
* Makefile.am, configure.ac, malloctest/init.c, termios03/init.c,
termios03/termios03.scn: Handle some of the VKILL and VERASE cases.
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* malloctest/init.c: Added error case with malloc of size 0.
* malloctest/init.c: Added test to check failure branch on calloc.
* heapwalk/init.c, malloctest/init.c: Update for heap extend changes.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
* malloctest/init.c: New test cases. Update for heap API changes.
* stackchk/blow.c: Update for heap API changes.
* malloctest/task1.c, stackchk/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* cpuuse/task1.c, cpuuse/tswitch.c, malloctest/task1.c,
stackchk/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* malloctest/init.c: Adjust allocation in test so it passes now that
heap overhead constant has been increased.
* malloctest/init.c, malloctest/malloctest.scn: Add heap resize test
for shrinking a block enough to need to free the newly unused
portion.
* malloctest/init.c, malloctest/malloctest.scn: Add error cases for
_Protected_heap_Get_information().
* malloctest/init.c: Fix warning.
* malloctest/init.c: Fix typo.
* malloctest/init.c: Add test case for heap resize block when the
resize creates a free block large enough to free.
* malloctest/init.c: Change sizes of heap/region and allocated objects
in heap to intptr_t so they can be larger than a single allocatable
object (e.g. size_t).
* malloctest/init.c: Do not generate alignment factors larger that will
not fit in a native integer.
* malloctest/init.c: Fix return status check.
* cpuuse/init.c, malloctest/init.c, monitor/init.c, monitor02/init.c,
putenvtest/init.c, rtems++/Init.cc, rtmonuse/init.c, stackchk/init.c:
Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all
POSIX tests. Add a clock_settime case for < 1988.
* malloctest/init.c: Add more test cases to cover heap better.
* malloctest/init.c: Add new test cases per Sergei. Make some of the
stranger cases operate directly on a freshly initialized heap. This
should make them more reproducible.
* malloctest/init.c: Add more tests per suggestions from Sergei
Organov.
* malloctest/init.c: Add include to remove warning.
* malloctest/init.c: Remove debug print.
* malloctest/init.c: Add test cases suggested by Sergei Organov
<s.organov@javad.com>.
* malloctest/init.c, malloctest/task1.c: Add test for posix_memalign.
* malloctest/init.c: Add some primitive testing of realloc() which also
does some positive path testing on the SuperCore heap.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* malloctest/init.c: Be explicit about need for default and floating
point attributes. This is just a style change.
