* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-22 | 1 | -1/+2 |
| | | | | * malloc04/init.c: Define p1, p2, p3, p4 extern (Avoid warnings). | ||||
* | 2011-07-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-12 | 2 | -41/+0 |
| | | | | | * malloc04/init.c, malloc04/malloc04.scn: Remove test cases which are obsolete. | ||||
* | 2011-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-05-06 | 1 | -4/+4 |
| | | | | * malloc04/init.c: Fix tests broken in warning pass. | ||||
* | 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-05-05 | 1 | -1/+10 |
| | | | | | | * devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c, malloctest/init.c, termios03/termios_testdriver_polled.c, termios04/termios_testdriver_intr.c: Remove warnings. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-10 | 1 | -16/+18 |
| | | | | | | PR 1661/testing * malloc04/init.c: Add public methods to get/set malloc heap pointer so the tests do not have to peer behind the API. | ||||
* | 2010-07-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-14 | 2 | -2/+18 |
| | | | | | | PR 1535/tests * malloc04/init.c, malloc04/malloc04.scn: Address issues in test. A mix of work by Ralf and Joel. | ||||
* | 2010-07-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-08 | 5 | -0/+191 |
* Makefile.am, configure.ac: Add test for exercising sbrk() extension to Malloc Family. * malloc04/.cvsignore, malloc04/Makefile.am, malloc04/init.c, malloc04/malloc04.doc, malloc04/malloc04.scn: New files. |
