Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
* malloc02/init.c, malloc02/malloc02.doc: Enable malloc dirty helper.
* Makefile.am, configure.ac: Add test for deferring free() from ISR and
for deferred free() processing.
* malloc02/.cvsignore, malloc02/Makefile.am, malloc02/init.c,
malloc02/malloc02.doc, malloc02/malloc02.scn: New files.
