Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into
new system state SYSTEM_STATE_TERMINATED. This reflects that all system
termination paths end up in _Internal_error_Occurred().
Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* heapwalk/init.c: Improve coverage.
* heapwalk/heapwalk.scn: Update.
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* heapwalk/init.c, malloctest/init.c: Update for heap extend changes.
* heapwalk/heapwalk.scn, heapwalk/init.c: Add missing _Heap_Walk test
cases to get back to 100% object coverage.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
* heapwalk/init.c, stackchk/blow.c: Update for heap API changes.
* heapwalk/init.c: Add test code for first free block pointer not
aligned.
* heapwalk/init.c: Add more cases.
* heapwalk/init.c: Add more automated corruption capability.
* heapwalk/heapwalk.scn, heapwalk/init.c: Add a test case.
* Makefile.am, configure.ac: Add shell of heap walk test for Santosh.
* heapwalk/.cvsignore, heapwalk/Makefile.am, heapwalk/heapwalk.scn,
heapwalk/init.c, heapwalk/system.h: New files.
