path: root/testsuites/libtests/flashdisk01 (follow)
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* flashdisk: Use rtems_blkdev_create()Sebastian Huber2018-08-071-8/+1
| | | | Update #3358.
* libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZESebastian Huber2018-07-301-4/+2
| | | | | | | | Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt stack size. This is an issue on some BSPs. Use CONFIGURE_INIT_TASK_TABLE_SIZE instead. Update #3433.
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-19/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* tests: Use floating point taskSebastian Huber2017-07-191-0/+2
| | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-1/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* testsuites: Remove BSP_SMALL_MEMORYJoel Sherrill2014-05-062-31/+2
* flashdisk01: Honor BSP_SMALL_MEMORYJoel Sherrill2014-04-221-2/+2
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-214-4/+4
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-3/+7
* fstests and libtests: Add contents to multiple documentation filesCynthia Rempel2014-01-081-3/+18
* libtests/flashdisk01: Include missing header fileSebastian Huber2013-10-161-0/+1
* libtests/flashdisk01: Update screen fileSebastian Huber2013-08-231-8/+10
* Use uint32_t instead of long. Use unsigned defines (Prevent overflows on ↵Ralf Corsépius2013-04-172-6/+6
| | | | 16bit targets)
* libtests/flashdisk01: Disable for small memory BSPSebastian Huber2013-04-082-0/+31
* Fix C files which had two semi-colons at EOLJoel Sherrill2012-05-311-1/+1
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-0/+3
* PR2040: libtests/flashdisk01: New testSebastian Huber2012-03-146-0/+1532
