* | flashdisk: Use rtems_blkdev_create() | Sebastian Huber | 2018-08-07 | 1 | -8/+1 |
| | | | | Update #3358. | ||||
* | libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE | Sebastian Huber | 2018-07-30 | 1 | -4/+2 |
| | | | | | | | | Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt stack size. This is an issue on some BSPs. Use CONFIGURE_INIT_TASK_TABLE_SIZE instead. Update #3433. | ||||
* | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -19/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | tests: Use floating point task | Sebastian Huber | 2017-07-19 | 1 | -0/+2 |
| | | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076. | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -1/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | testsuites: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 2 | -31/+2 |
* | flashdisk01: Honor BSP_SMALL_MEMORY | Joel Sherrill | 2014-04-22 | 1 | -2/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 4 | -4/+4 |
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -3/+7 |
* | fstests and libtests: Add contents to multiple documentation files | Cynthia Rempel | 2014-01-08 | 1 | -3/+18 |
* | libtests/flashdisk01: Include missing header file | Sebastian Huber | 2013-10-16 | 1 | -0/+1 |
* | libtests/flashdisk01: Update screen file | Sebastian Huber | 2013-08-23 | 1 | -8/+10 |
* | Use uint32_t instead of long. Use unsigned defines (Prevent overflows on ↵ | Ralf Corsépius | 2013-04-17 | 2 | -6/+6 |
| | | | | 16bit targets) | ||||
* | libtests/flashdisk01: Disable for small memory BSP | Sebastian Huber | 2013-04-08 | 2 | -0/+31 |
* | Fix C files which had two semi-colons at EOL | Joel Sherrill | 2012-05-31 | 1 | -1/+1 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -0/+3 |
* | PR2040: libtests/flashdisk01: New test | Sebastian Huber | 2012-03-14 | 6 | -0/+1532 |
