* | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -21/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -3/+6 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-08-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-02 | 5 | -0/+296 |
* Makefile.am, configure.ac: Add test for rtems_print_buffer(). * dumpbuf01/.cvsignore, dumpbuf01/Makefile.am, dumpbuf01/dumpbuf01.doc, dumpbuf01/dumpbuf01.scn, dumpbuf01/init.c: New files. |
