This adds a pthread that runs the test as well to increase test
coverage. The original test would have passed if all threads returned
the address of the Init task's errno since no additional threads or
tasks were checked.
This adds a test verifying basic TLS functionality in loadable modules
now that at least one architecture supports it.
Updates #4682
Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt
stack size. This is an issue on some BSPs. Use
CONFIGURE_INIT_TASK_TABLE_SIZE instead.
Update #3433.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
This is a merge of the RTL project.
