* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -1/+1 |
| | | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | ||||
* | libtests/dl*: Rename source files | Sebastian Huber | 2019-11-26 | 1 | -0/+61 |
Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use *.cc for C++ source files instead of *.cpp to be in line with other C++ source files. Update #3818. |
