- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Trampolines or fixups for veneers provide long jump support
for instruciton sets that implement short relative address
branches. The linker provides trampolines when creating a
static image. This patch adds trampoline support to libdl
and the ARM architecture.
- The dl09 test requires enough memory so modules are outside
the relative branch instruction ranges for the architecture.
Updates #3685
