* | libdl: Add powerpc large memory and small data support. | Chris Johns | 2019-02-09 | 7 | -78/+95 |
| | | | | | | | | | | | | | | | | | - Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685 | ||||
* | libtests/dl02: Update the rtl-shell path. More verbose test. | Chris Johns | 2019-02-09 | 1 | -9/+12 |
| | | | | Updates #3686 | ||||
* | libdl: Add object file dependencies to track references | Chris Johns | 2018-11-22 | 14 | -0/+1184 |
Tracking references lets us manage when an object file can be unloaded. If an object file has references to it, it cannot be unloaded. Modules that depend on each other cannot be unloaded. Updates #3605 |
