#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
