* | libtests/dl*: Do not generate files via "echo" | Sebastian Huber | 2019-11-25 | 1 | -0/+1 |
| | | | | | | Add the static files to the repository. This simplifies the build. Update #3818. | ||||
* | libtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 3 | -88/+91 |
* | dl06/dl06-o1.c: Remove set, not used warning | Joel Sherrill | 2018-08-15 | 1 | -1/+4 |
* | libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE | Sebastian Huber | 2018-07-30 | 1 | -4/+3 |
| | | | | | | | | Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt stack size. This is an issue on some BSPs. Use CONFIGURE_INIT_TASK_TABLE_SIZE instead. Update #3433. | ||||
* | testsuites/dl06: Add a test for RAP format. | Chris Johns | 2018-04-12 | 8 | -0/+349 |
This test loads a RAP format file that contains calls that are not in the kernel and linked from libm. It uses and test rtems-ld. Update #2769 |
