path: root/testsuites/libtests/dl05 (follow)
* libtest: <rtems/test.h> to <rtems/test-info.h>Sebastian Huber2020-07-231-1/+1
| | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199.
* Canonicalize config.h includeSebastian Huber2020-04-162-2/+2
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* libtests/dl*: Rename source filesSebastian Huber2019-11-262-0/+0
| | | | | | | | Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use *.cc for C++ source files instead of *.cpp to be in line with other C++ source files. Update #3818.
* libtests/dl*: Use rtems_tarfs_load()Sebastian Huber2019-11-261-2/+2
| | | | | Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the memory demands of the tests.
* libdl: Add powerpc large memory and small data support.Chris Johns2019-02-091-1/+21
| | | | | | | | | | | | | | | | | - Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685
* libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZESebastian Huber2018-07-301-4/+2
| | | | | | | | Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt stack size. This is an issue on some BSPs. Use CONFIGURE_INIT_TASK_TABLE_SIZE instead. Update #3433.
* libdl: Fix the tests loading the correct filesChris Johns2018-04-121-1/+1
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-102-50/+3
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* dl01, dl02, dl05: Fix unresolved printf symbolSebastian Huber2017-11-151-2/+7
| | | | | | | | The link time wrap of printf leads to unresolved symbols in the loadable modules. This resulted in infinite loops and test timeouts. Use rtems_printf() for output. Update #3199.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* tests: Use floating point taskSebastian Huber2017-07-181-0/+2
| | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076.
* tests: Fix build dependenciesSebastian Huber2017-06-131-1/+1
| | | | | | See also: https://www.gnu.org/software/automake/manual/html_node/Built-Sources-Example.html
* testsuites: Fix build dependences for generated files.Chris Johns2017-05-111-0/+2
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-041-8/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* libdl: Support link ordered loading of ELF sections.Chris Johns2017-03-311-1305/+1357
| | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959
* libdl: Add C++ exception support to loaded modules.Chris Johns2016-12-146-1199/+1457
| | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767.
* testsuite: Add libdl/dl05 reloc test.Chris Johns2016-09-088-0/+1542
