- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt
stack size. This is an issue on some BSPs. Use
CONFIGURE_INIT_TASK_TABLE_SIZE instead.
Update #3433.
Update #3382
The link time wrap of printf leads to unresolved symbols in the loadable
modules. This resulted in infinite loops and test timeouts. Use
rtems_printf() for output.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
See also:
https://www.gnu.org/software/automake/manual/html_node/Built-Sources-Example.html
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
The ARM C++ exception ABI uses an address ordered index table to
locate the correct frame data and this requires the EXIDX sections are
loaded in the order the order the matching text is loaded.
The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch
adds support to load those flagged sections in the linked-to section
order.
Updates #2955.
Closes #2959
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
