#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt
stack size. This is an issue on some BSPs. Use
CONFIGURE_INIT_TASK_TABLE_SIZE instead.
Update #3433.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
