path: root/testsuites/libtests/dl03 (follow)
* Canonicalize config.h includeSebastian Huber2020-04-163-3/+3
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* libdl: Add powerpc large memory and small data support.Chris Johns2019-02-093-0/+280
| | | | | | | | | | | | | | | | | - Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685
* libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZESebastian Huber2018-07-301-4/+3
| | | | | | | | Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt stack size. This is an issue on some BSPs. Use CONFIGURE_INIT_TASK_TABLE_SIZE instead. Update #3433.
* libdl: Fix the tests loading the correct filesChris Johns2018-04-121-11/+11
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-19/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* libdl: Use self-contained recursive mutexSebastian Huber2018-02-071-1/+1
| | | | Update #2843.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* dl03/dl-cache.c: Fix duplicate const warningJoel Sherrill2017-06-211-1/+1
* libdl: Add C++ exception support to loaded modules.Chris Johns2016-12-141-0/+2
| | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767.
* testsuite: Add libdl/dl03 cache test.Chris Johns2016-08-156-0/+489
