path: root/testsuites/libtests/deviceio01 (follow)
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-2/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-214-4/+4
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-2/+6
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-1/+4
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-115-13/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-1/+1
| | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+1
| | | | | | | | | * devfs04/Makefile.am, deviceio01/Makefile.am, monitor02/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, termios01/Makefile.am, termios03/Makefile.am, termios04/Makefile.am tztest/Makefile.am: Add missing files.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-08-06 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-077-0/+393
PR 1654/testing * deviceio01/init.c, deviceio01/deviceio01.doc, deviceio01/deviceio01.scn, deviceio01/test_driver.c, deviceio01/test_driver.h, deviceio01/Makefile.am: New test added. * Makefile.am, configure.ac: Changes to added above test. * tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
