brains GmbH.
The SHA512 functions may use huge amounts of stack space if compiled without
optimization.
Updates #4625.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
